Secondary Project Provider for lvclass to make custom menus
I am trying to make a custom menu item when a user right-clicks on a lvclass in the labview project.  The goal is to make it so that a developer could select a custom member template.  I'm pretty sure it can be done by creating a Secondary Project Provider.  I putz'd around with the documentation/examples and they did the job, but I was hoping someone might have an example of what I am trying to do so that I don't waste a ton of time on deadends.  Thanks.
(1,256 Views)
I made a secondary provider a while ago to allow me to right-click on the class private data item (myclass.ctl) and change the colour of the box that you see in the controls.
It doesn't add a new VI, but it might be useful to take a look at - if not, then feel free to ignore!
I'm shortly going to be trying to implement a project provider to clone a template class object (in the style of New > Actor) so if I finish that anytime soon I'll also post it here.
GCentral
(1,197 Views)
Thanks I'll give it a try.
(1,179 Views)
