Securing CompactRIO
We have a CompactRIO Controller (cRIO-9067), which is connected via Ethernet to our network. Is there a way that you must enter a password before loading a new programm? Because we had an incident, where somenone loaded his programm on the wrong controller.
(3,485 Views)
AFAIK you only can disable project access fully or not. Without project access to the controller you can’t deploy programs from a LabVIEW project anymore but have to replace the rtexe with some other means such as SSH, which is password controlled. Or you use the System Control API to create your own deployment tool.
Rolf Kalbermatter  My Blog
(3,448 Views)
