Security for the file created
Hai
 I'm creating a configuraton file via labview in a text file,my customer needs an security for the configuration file ..i have stucked,please help me out ..is it possible to create config file in anyother type of file??
Message 1 of 8
(4,238 Views)
You can encrypt the content while writing to configue file and decrypt it whlie reading it back. Refer following.. Also if you want you can hide file.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 8
(4,209 Views)
As I recall the book, A Software Engineering Approach To LabVIEW, had a method of generating an encrypted INI file.  Basically, the idea was to create a wrapper around the NI INI vi's that would handle the data encryption and reads/writes of the file to disk. You might want to get a copy of that and check it out.
Alternatively, you could use the Windows registry to store protected data.
Jason
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
Message 3 of 8
(4,185 Views)
A more secure method would be to use the Blowfish algorrithm to encrypt the data.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 8
(4,180 Views)
Thank your reply,let me try with the algorithm...
Message 5 of 8
(4,165 Views)
Thank you sir..i'm trying with this..
Message 6 of 8
(4,164 Views)
hello sir
         i tried this ..instead of creating an txt file i created an pdf file ..when i tried to open the file it says it is not valid pdf file but this config file is read during the execution and im getting the exact output..
Message 7 of 8
(4,136 Views)
@Sumithra Nagappan wrote:
hello sir
Of course you can't open it with a PDF reader. Simply putting a .pdf extension on a file does not mean it is a PDF formatted file. The Blowfish algorithm is used to encrypt and decrypt data. It is not used to create PDF files.
Mark Yedinak
LabVIEW Champion
Message 8 of 8
(4,126 Views)
