Security "Lock" in need
Dear all,
Have you worked/ come across any programming on software authorisation using Hardware lock & serial number of PCMCIA card?
I would really appreciate if you can share your experience here with me. And, I believe your experience will in turn benefits many others.
Sample code(s) welcome.
Best regards
ian.f
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 1 of 19
(4,371 Views)
Or locked to an identifying feature of the computer such as the serial
number of the processor?
Message 2 of 19
(4,371 Views)
"ian.f" wrote in message news:<506500000008000000B8640000-1031838699000@exchange.ni.com>...
> Dear all,
The only experience that I have with it is that customers get terribly
upset when an entire production line goes down because the PCMCIA card
broke and can't be replaced because the software locks them out.
Les Hammer
Complete Test
Message 3 of 19
(4,371 Views)
What if locking using Serial Number of the PCMCIA card is a must? Any suggestion?
Ian F
依恩与LabVIEW
Message 4 of 19
(4,371 Views)
wanna share your experience?
Ian F
依恩与LabVIEW
Message 5 of 19
(4,371 Views)
Would it work with a serial number of the hard drive instead?
Message 6 of 19
(4,371 Views)
There is a knowledge base about this entitled "How Can I Read the Serial Number of a GPIB Card programmatically?" That will enable you to read the serial number programatically. The only caveat is that this only works with ni488 1.7 and earlier.
Best Regards,
Aaron K.
Application Engineer
Message 7 of 19
(4,371 Views)
My company uses the volume serial number XORed with a couple of secret
numbers to make keys that get stored as a file on PCMCIA cards for
customer use. I can't tell you the details because of confidentality,
but it is relatively reliable.
The only problem you face is training the user to use your special
erase function to clean the disk, instead of formatting it, which
would erase the file.
You can use Labview to read the volume serial number, and then
calculate the key file for you, then write the key to a file on that
card.
Message 8 of 19
(4,231 Views)
hi Aaron
Thanks for putting in your time for this.
Actually, I am looking for a sample code which Acquire the Serial Number of a DAQ Card (PCMCIA) and of which way would be the best to use this number for locking purpose.
Do I need to programme it as a constant to check with the acquired s.num?
please advise.
b.rgds
Ian F
依恩与LabVIEW
Message 9 of 19
(4,371 Views)
Hi David,
Thank you for your input.
Basically, I do not intend to create a file and write into the card but to acquire the card's Serial Num and compare it with a constant value (could be read from file) to ensire that the software is use in conjuction with the particular PCMCIA card.
I have simple idea about how to do this. However, any better, if not the best, solution(s) is always welcome.
Cheers.
ian.f
Ian F
依恩与LabVIEW
Message 10 of 19
(4,231 Views)
