03-13-2007 09:39 PM
03-14-2007 01:16 AM
Hi Ian,
Are you an administrator on this test-station? Can the ports be used through Hyperterminal? How does your application "setup" a port - are there calls to a special driver/dll? Does your app only use VISA calls? What happens if only one port is setup (instead of all/simultaneously)? When all else fails (and sometimes before all else fails
- ) I check the web to see if anyone else is having the same problem.
Good luck! ![]()
03-14-2007 08:08 AM
