Segmentation Fault on startup - RH Fedora 2
I get this error after using tune2fs to get around the directory index problems of ext3 filesystems mentioned in the knowledge base.
Running Fedora 2 on Dell Pecision 670, dual 3GHz Xeons, 2GB RAM:
bwhite@localhost:~$ /usr/local/lv71/labview
LabVIEW caught fatal signal
7.1 - Received SIGSEGV
Reason: unknown
Attempt to reference address: 0x0
Segmentation fault
Message 1 of 24
(4,842 Views)
Are you installing LabVIEW on a freshly formatted computer? Does this computer have any previous versions of LabVIEW installed? Did the installation give any error messages?
Kileen C.
NI
Message 2 of 24
(4,839 Views)
This is a fresh installation on a new computer. No previous NI software exists. The install from RPMS went well with no errors. When I first started labview, I received an error that I "fixed" with tune2fs to turn off the funky ext3 filesystem indexing concerning "." and ".." directory index entries. After that I get this new "unknown" error addressing 0x0.
Message 3 of 24
(4,839 Views)
Hm, this is a new instance of this error. Do you have Fedora Core 1? I know our previous issues with this seg fault was different based on if Fedora Core 2 was installed fresh or installed after Fedore Core 1 had already been installed. The funky ext3 filesystem indexing (fixed with tune2fs) was needed only if installing Fedora Core 2 fresh. Upgrading from Fedora Core 1 with Core 2 did not exhibit any problems.
I will go ahead and submit a report to reproduce this issue. In the meantime, try installing Fedora Core 1 and then upgrading to Core 2 to see if that helps.
Thanks!
Kileen C.
NI
Message 4 of 24
(4,839 Views)
check the file permissions on /tmp
All users should have read, write, and execute permissions (chmod 777)
set for the /tmp directory.
You'll get a sig fault if LV cannot write to that directory. Reply back
if it works.
-kevin
Message 5 of 24
(4,724 Views)
I'm not keen on the idea of (re)installing two OS's; it took a few days to get one setup, and I don't relish the thought of going through that again. Would uninstall/reinstall of LabView make any difference since I made the tune2fs change?
Message 6 of 24
(4,838 Views)
This is the permissions on /tmp:
[bwhite@ansel GSSDA]$ ls -ld /tmp
drwxrwxrwt 11 root root 57344 Sep 29 11:04 /tmp
Message 7 of 24
(4,723 Views)
After uninstall/reinstall:
[bwhite@ansel paper]$ /usr/local/bin/labview
Reason: address not mapped to object
Attempt to reference address: 0x27e7110c
Segmentation fault
Message 8 of 24
(4,837 Views)
Attached are the failure logs if that helps.
Message 9 of 24
(4,837 Views)
Oh well. It was worth a try.
Message 10 of 24
(4,721 Views)
