Select a list of tasks from a list and then execute the selected tasks
from a list of possible tasks (ie do a wait, write a command ...), I want to select some of the tasks (one task could be selected several times) and then executes the selected tasks.
How can I do that ?
Laurent.
(3,281 Views)
Laurent,
since your description of your question is.... well... at least in my opinion not sufficient for an answer, i can only guess. and the guessing a am doing here is, that you want to use a state machine. please take a look into the frameworks delivered with LabVIEW.
Norbert B.
Norbert
Expert: Geometry
(3,277 Views)
Hi Norbert,
sorry for the previous description. I do not think this is a state machine I need.
I have a list of tasks (wait, do a write, do a read ..). Each task is a sub vi.
I want to select out of this list a sequence of tasks (ex: wait, do a write, wait, do a read).
Once I have selected the sequence, I want to execute it.
Laurent.
(3,274 Views)
Laurent,
this sounds a bit like the main functionality of TestStand Smiley Very Happy
Nevertheless, perharps you should take a closer look onto the "queued message handler" architecture then. this fits in a more confeniant way.... each message "state" includes one subVI and the array of messages is built in the beginning by your interface.
maybe this helps a bit more Smiley Happy
Norbert B.
Norbert
Expert: Geometry
(3,268 Views)
Norbert,
I did find an example of a queued message handler architecture, the overall structure could somehow fit with my needs but it is mostly dealing with response notifier. May be I did look into the wrong vi ?
Laurent.
(3,263 Views)
the main issue I have is the following: once I select the list of tasks, I have a 1D array of string (ex: wait, do a write, wait, do a read).
Each string correspond to a vi and I want this vi to open when I click on the string (to change the parameters in the vi).
Do some one know how to do it ?
Laurent.
(3,259 Views)
Laurent,
reading your prerequisites confirms me in my opinion that you should use queued message handler as your architecture. I would create it in a following way:
there should be an "idle" or "User Interface"-case in the architecture which enables you to queue messages into the 1D-String-array which controls the architecture. after hitting a "run"-button, you would disable enqueuing and start off retrieving message after message from the queue executing the appropriate VI for each message until you emptied the queue or a certain termination-message is included in the queue.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(3,240 Views)
