Select active hypertrend group programmatically
I have two hypertrend charts with four groups in each chart. Is it possible to have both charts select the same group number when one of them is manually changed??
(2,857 Views)
Yes,
You can have create a connection on your second hypertrend like the one shown below:
Hypertrend2.ActiveGroup = Hypertrend1.Active Group.
This connection pretty much sais that the active group on the second hypertrend will be the same as the one selected on the first hypertrend (just remember that ActiveGroup is defined by a number and not a name).
Also, you can have a Pot that selects the multiple actvie groups on both hypertrends. The connections on the hypertrend objects would look like this:
hypertrend1.activegroup = Pot1
hypertrned2.activegroup = Pot1
I hope this helps.
VG
(2,857 Views)
I have not found a property node that would let me write a value to the active group. I also have not found one to read the array of available group names, just the 'count' for the total number in the group or just the name of the selected group.
(2,858 Views)
