Select an Item for an index array an export to ms access
Hi
I'm developing an app using MS ACCESS db in labview, I want to use the info in some tables to create reports, but I don't know how to select an especific item ( index in row X, column y)  to used, is there is a way to do this?
any help is welcome
many thanks in advance
(2,522 Views)
Yes there is. See the attached file for a quick overview of the process. You will also need a bit of knowledge about the database language SQL, but its not hard.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,513 Views)
