Select data between points on a chart
I will have a analog signal come into my program and be charted for X period of time. Then after the data has been charted I would like to move a cursor to a certain start and a certain stop. After the cursor has moved I would like to export only the data between the two cursor marks... How do I do this?
Bryan
(3,111 Views)
Hello Bryan,
Check the anex vi, hope it helps,
Paulo
(3,106 Views)
Hi Bryan
Just a little example. Use the propertynode of the graph to extract the signal.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,103 Views)
Sorry forgot the attachment...
(3,100 Views)
