Select file dialog
Select In my vi below, I read the contents of a file, put it in the List-Scenario ring and assign each column the corresponding ring (Ring1,Ring2,Ring3,Ring4). And that's done.
Now what I want to change in this vi: instead of reading the file directly, I want when the user clicks on the List_Scenarios ring a window to appear for the user to choose their own file and the code continues.
How do I do this please?
(1,831 Views)
There is a File Dialog in the palettes.  Look in the File I/O->Advanced File Functions palette.
(1,822 Views)
Accepted by topic author Ngouda
  • The scenario list is already overloaded because it is used to select a scenario, so you should not use it to select a file. Add a button to select a file, or do an event for value change on the path control.
  • The case structure in the test case is not needed, because if a latch action button changes it is guaranteed to be true (assuming the default value is FALSE).
  • Your exit button has the wrong mechanical action.
  • You probably want to write strings[] into the rings, not "ringtext.text".
  • etc...
(1,807 Views)
Hi @altenbach, @crossrulz,
Thanks you for your reply.
Its works now what I want.
Have a good day
(1,729 Views)
