Select multiple ROIs and set properties to each of them
Hi all,
I am now working on a project dealing with thermal camera images. What I need to do is to set several regions of interests and assign some specific properties like average temperature and emissivity to those ROIs.
So I was wondering:
1. is that possible to select several ROIs with an array keeping updating ROIs the user has chosen on the front panel? (Or each ROI could have a cluster on the front panel that contains its properties, that can be changed later.)
2. is that possible to set specific properties like temperature to the specfic ROI, and those properties will be updated to the ROI?
Thank you so much, and looking forward to some great ideas or advice.
Cheers,
Sunming
(2,858 Views)
Accepted by topic author sunming
Hi All,
The attachment is what I have currently made. However, instead of creating a .txt file to display information, it would be perfect to display the ROI's name and its properties in the front panel, like in the first column is ROI 1, ROI 2, ROI 3, etc., and the other columns will deal with some information about the specific ROI and its properties.. Since I could not find anything similar here, I really need your help.
Sunming
(2,810 Views)
