Select output of a SubVI
in my SubVI you can enter your name with a string-input.
Now i want to use this string (name) in another VI, so the name have to be a output of the SubVI.
But i can´t select the string-input as a output?
Is this right? How can i solve this problem?
(3,498 Views)
think dataflow: an indicator can be the output of your VI...
(3,492 Views)
I can connect the string-input to a string-output, which could be used as output.
Is it possible, that you can´t see the string-output in the front panel?
(3,474 Views)
I have no idea what you are trying to describe.  Please attach your VI's.
From your question, it sounds like you could benefit from taking LabVIEW tutorials.
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(3,441 Views)
Are you trying to figure out how to assign connectors to the connector pane?
I think you would get a solution instantly if you would attach a simplified version of your VI and explain the problem in more detail.
(3,432 Views)
Hi dulfried,
Yes: hide it…
(3,420 Views)
