Select tool and escape characters in string
I would like to select a directory path using the select functions. The string is terminated at the position of the backslash,
Example "C:\Program Files\Microsoft Games"  will become "c:"
How do I get around this
Thank you
JIm
(2,668 Views)
You do not show what the Select function is wired to and what is doing the truncating. Obviously the select function is not doing any truncating. Instead of strings, use the path constant for paths.
(2,657 Views)
Accepted by topic author Jim_Glanz
Thanks for the help, It was the indicator that was truncating the line.
Sorry for the questions but I am very new to labview, it is much different than CVI
Jim
(2,643 Views)
