Selectable variables for graph/toggle graph from dropdown
Hello. I am currently working on an interface for a rainwater collection and analysis system. It is currently using an Arduino UNO R4 and a few sensors for measuring rainwater pH and total dissolved solids, as well as the nearby temperature and humidity. I currently have all of the information being read from the serial of the Arduino, using spaces to separate the different variables, convert them into arrays, and display them on the interface.
Ideally, I want to have that data also displayed on an xy graph, with the variables being something I can pick from a dropdown. So I could have the graph display rain sample # vs humidity, rain sample # vs pH, or even something like temperature vs pH.
Right now though, I just want to at least show the graph displaying rain sample # vs humidity, temp, etc. when selected from a dropdown. All I have so far is the build xy graph vi with it set to NOT clear the data on each call, and 4 graphs (one for each y variable). I have an enum connected to a case structure for selecting which graph I want, but I am unsure how to hide/toggle the other graphs. I attached what I have so far, but I'm stuck. Any help would be greatly appreciated.
(1,579 Views)
Accepted by topic author jvaldez12
You can use a "Property Node" for each graph and make it visible true or false depending on the condition you have.
To show the property node, right click on the graph you want, then select CREATE -> PROPERTY NODE->Visible
(1,545 Views)
Thank you! I will try this as soon as I can.
(1,503 Views)
It worked perfectly! Thank you!
(1,470 Views)
