Selected file is not a valid library
Hello
I got a DLL and tried to use it in my programm with CLFN. But when I select library in CLFN dialog box, I receive the message "The file selected is not a valid library". In other hand, DLL is provided with an example program (.exe) which works fine. DLL is in attachement.
(3,684 Views)
Hi Err,
LabVIEW can't find an exported function in this library. Maybe your exe sends messages to this dll.
Mike
Message Edited by MikeS81 on 01-19-2009 03:14 PM
(3,677 Views)
Thanks, Mike!
Does it mean that DLL crashed?
(3,672 Views)
Hi Err,
i'm not sure. Do you have the source code for the example exe? Do you have a description of your dll?
No, it does not mean the dll crashed. You (the dll creator) can descide which function shall be exported.
Mike
Message Edited by MikeS81 on 01-19-2009 03:41 PM
(3,669 Views)
I guess your file is damaged. It has some bad data. Look at the bottom of the export table. Get a new file
Message Edited by t06afre on 01-19-2009 05:12 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,643 Views)
