Selecting Tabs
I found this vi for selecting tabs on the website. I would like to replace the numeric control that selects the tabs with push buttons.
Is this possible??
Help!!!!
(2,345 Views)
Hey Dugy88,
This is definitely possible.  In the VI you have posted the value of the numeric control causes the Case Structure to give a different value to the Property Node that determines which tab appears selected.  All you need to do is design a VI that determines which button has been pressed and cause a value to be written to the property node based on that.
I went ahead and made a simple VI that does what I mentioned above.  Check it out and see if it works like you were describing.  You can also do this a number of different ways but this way made the most sense to me.
Eric L.
Applications Engineering Specialist
(2,337 Views)
