Selecting data with cursors on an X-Y Graph
I would like to make an interactive XY plot with two cursors. These cursors will allow the user to select a range of data, and send the selected data to an array. Sending the data to an array and referencing the positions to the array is no problem, but I cannot get the two cursors to work simultaneously.  I am monitoring the positions on the front panel, and both indicators display the same data. How do I set the property nodes to treat each cursor as separate, and collect separate data from each? Thanks.
(4,048 Views)
Before you can get the cursor index or cursor position, you have to first set the active cursor.
Message Edited by Dennis Knutson on 03-24-200609:57 AM
(4,052 Views)
Thank you, I indeed was making this much more difficult.
(4,037 Views)
I think you need to specify the active cursor on the property node that
you are trying to obtain the position information from.
(4,026 Views)
I am trying to achieve the same goal as bassbuckeye (allowing the user to select a range of data, and sending the selected data to an array), however I cannot get the active cursor method to work (I'm getting "Error 1077 occurred at Property Node (arg 1) in Untitled 2 - Invalid property value.")
In the past I remember coming across an example that ships with Labview that was demonstarting a completely different point. However, I remember it enabled the user to position two vertical yellow lines on a graph of some sort, and would run analysis on the subset of data between the line. Trouble is I can't find it again to copy their method...
Any ideas either how to solve the error mentioned, or which example I might be talking about?
Many thanks,
Ian Haigh
(3,854 Views)
Scrap that - I just solved my own problem!
Not sure why it wasnt working before but with a bit of faffing I got the active cursor method to work.
Btw, the example I was thinking of was called 'Cursor' (!!) and can be found at C:\Program Files\National Instruments\LabVIEW 7.1\examples\express\Cursor.vi
Ian
(3,836 Views)
