Selecting "Show Control" on constant cluster crashes LabView
Hi!
It's not critical but it happens if to make the following
things:
0. Opening Blank VI
1. Placing pre-created cluster (typedef) with al least one control reference inside.
2. Changing cluster to constant.
3. Going to block diagram.
4. Right-clicking on the control ref num inside cluster
and selecting "Show control" in the context menu.
Result: LabView 8.0 on WinXP crashes saying there's fatal internal error in undo.cpp(4587).
See attached for sample VI, cluster typedef and error log.
Note: I understand that there's no sense to make control visible inside control ref num as the cluster is not displayed on the front panel when it's constant but anyway it's not foolproof 🙂
Rashid.
P.S. I've posted this error through special form on NI.com but maybe I did something wrong as I got no answer so I'm posting this issue here.
Message Edited by Rashid on 02-22-2006 11:32 AM
(2,702 Views)
Hi Rashid
I confirm the LV8, W_XP crash.
take care
Pawel
Message Edited by pawel on 02-22-2006 04:49 PM
(2,686 Views)
