Selection of DAQ
We would like to acquire the Piezo electric material properties such as voltage, current, resistivity and temperature due to the vibration or temperature variation. So could you please suggest me which kind of  DAQ system is best for acquire the above parameters.
Note:  Based on the Piezo electric material properties generating voltage variation will be there like mV or V
(2,256 Views)
You should contact you local NI sale representative. they are there for that.
Benoit
(2,245 Views)
Not nearly enough data...
How many channels? How fast? Will the same system be controlling a shaker table or temperature chamber? What exactly is the system as a whole doing? What sort of environment will it be working in?
These are also questions that your NI rep will have.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,240 Views)
