Selection of Mulitple Signals from one Input
Hi, I am building a program that acquires 128 channels of signals, from one input.  I would like to seperate these signals on different graphs for viewing.  I am able to seperate the first eight signals using the Select Signals Icon, but after that I cant.  The problem is the Select Signals Icon only had 8 indices, so I can select a signal from 0-7.  Is there any built in functon to select n channels, or is there another way I can seperate them???
Thanks I really need to figure this out soon,
(2,360 Views)
Try using "split signals"  its in the signal manipulation pallet.  If you left click and drag the control it will expand to multiple outputs.
Gold
(2,354 Views)
hey thanks that worked
(2,352 Views)
