Selective copy from 2D array to another 2D array
Hi everyone,
Hope you are all doing well
I am currently struggling on a bit code that I cannot get to work properly. I have two 2D arrays (typically, pixel values from two images taken from two cameras, not always the same) and I want to copy the pixel value from the first array (let's call it Array Src) to the second array (Array Dst) - effectively replacing Dst's values with Src ones. However, they are two difficulties here: (1) Src and Dst does not always have the same size, (2) Src can be bigger than Dst, but it can also be smaller. As a matter of fact, the final size will always be the one of Dst, regardless if Src is bigger, equal in size, or smaller than Dst. If Src is smaller than Dst, the value from Dst should be kept but most importantly Src should be centered then on Dst.
I tried to make the VI code I attached to the message, and I also copy a screenshot here:
The code itself terminates without an error, but the problem is that all the values inserted into Dst are exactly the same, despite Src having lots of different value. I tried to locate the issue and edit the variable types especially for the indices, but it still does not work properly (there is some left overs of these attempts in the picture and VI I attached).
Also, I have the feeling that my code is perhaps too complicated for what I am trying to do, but this is just a feeling...
If someone tried to do something similar in the past, of if you could have a look at the code to help me with this issue, that would be awesome.
Thank you in advance for the help, and I hope I was clear enough in the description of the situation
Best
Vivien
(4,568 Views)
Can you explain the insert point calculation? All you probably need is "replace array subset" as follows (after calculating the insert points)
(Also I seriously doubt that your code should have anything orange. All calculations are on integers)
(4,556 Views)
Accepted by topic author VWalter
OK, after further study, this should get you close to what you want.
(4,533 Views)
Hi altenbach. Thank you for the really swift reply!
After your first post I modified my code to insert your suggestions - which of course worked perfectly and solved my problem - and I was about to submit it when you replied. And your code is definitively way simpler than mine!
So thank you a lot for the help 🙂
(4,510 Views)
Actually it was still a little complicated. We don't need anything green or coercion dots.
I also include a little tester to verify correct operation.
(4,498 Views)
