Selestivly hiding of controles
i want to use a LED. i have 3 condition.
i want for each condition it should give me different colour
(2,546 Views)
There's a couple ways to go. One way is to use a picture ring with three different images in it (see the example here. Finally, you could use the Colors property of a single Boolean and change that depending on the value of your condition.
(2,546 Views)
Oops. Here's a corrected post with the right links.
There's a couple ways to go. One way is to use a picture ring with three different images in it (see the example here. You could also change the visiblity of multiple controls as shown in the example here. Finally, you could use the Colors property of a single Boolean and change that depending on the value of your condition.
(2,546 Views)
see attached vi
(2,546 Views)
