Send ASCII command (STAT) thru ETHERNET connection
Hello everyone, I am trying to send a STAT command and receive back data using a ethernet connection. Can anyone strat me out with this..
Rulee
Message 1 of 19
(8,491 Views)
Send a STAT command to what?
Message 2 of 19
(8,486 Views)
To what instrument?
The easy way would be to use VISA
  1. Use the instrument's IP address as the VISA resource
  2. Use a VISA Write to send your command text string "STAT" with the proper termainator (?).
  3. Use a VISA Read to receive the responce from the instrument
=== Engineer Ambiguously ===
Message 3 of 19
(8,485 Views)
In addition to what instrument/device? There is also the question of the protocol that the device uses to communicate over Ethernet.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 19
(8,480 Views)
To an ACU which is a control system, I have been using Tera Term followed by a MACRO that I wrote to connect thru ethernet, send stat command and receive data back, Elevation, Azmith, Polar and signal strength.
Rulee
Message 5 of 19
(8,464 Views)
Here is a screen shot of a sub-vi I use to get information from and to control a Thermotron 8800 thermal chamber through Ethernet.
Of course you will have to parse the text returned instead of convert string to numbers like I do here.
Message 6 of 19
(8,455 Views)
Great! i will try this..Thanks!
Rulee
Message 7 of 19
(8,451 Views)
OK, so you are using a telnet connection to the device. You can do the exact same thing using the telnet VIs for LV.
Mike...
LabVIEW Champion
Message 8 of 19
(8,444 Views)
Built Thermotron 8800 VI WITH VERSION 8.2.1 and keep getting (Selecting Values have wrong type) can someone help. Here is the VI
Rulee
Message 9 of 19
(8,397 Views)
Well this was meant as an example ot how to comunicate with an instrument over Ethernet using the TCP protocal VI's.
If you actually need to comunicate with a Thermotron SE-8800 thermal chamber controller via Ethernet I will post the full VI set.
In general make your selector an Enumerated type and your case needs to match your selector values with a case for every value.
Message 10 of 19
(8,388 Views)
