Send Email Express VI works, SMTP VI's dont
I cannot get the "Send" VI from LabVIEWSMTPClient.lvlib to work.  I get error" Possible reason(s): LabVIEW:  The network is down, unreachable, or has been reset."
I have also tried using the "Send Email using SMTP Client" example program and I get the same error.
My initial thought was maybe the firewall at my company is blocking the traffic, however the "Send Email" Express VI works just fine with exactly the same configuration and credentials.
Does anyone have any insight why I might be seeing this behavior?
Corey Rotunno
(3,928 Views)
Can you submit your VI for us to look at?
(3,908 Views)
See below for my VI. Interestingly enough it works now. I am not sure what is different than before, I am a little perplexed. Since my first attempt I did enable POP and IMAP access to the gmail account but to my understanding that should not effect being able to send an email or not.  Thanks anyhow!
Corey Rotunno
(3,894 Views)
