Send To context menu arguments with LabVIEW executable
I am have written a VI (and built it as an exe) to perform operations on a file, or array of files.  I get the list of files as application arguments.  I have added my exe to the Send To folder in windows so it appears in the context menu when I right click on a file.  The problem is, LabVIEW opens the file with its registered application.  I have read that Send To will pass the file selected to the application as arguments.  The question is how do I set up LabVIEW (or Windows) to pass the selected file(s) as an argument rather than launching it?
Thank you,
Michael.
(3,179 Views)
Hi Michael,
What are the files that you are passing? What exactly does you .exe do? is it possible to have a look at the source code, a screen shot will suffice.
Regards
Andrew George @ NI UK
(3,162 Views)
Problem solved.  I had forgotten to check the box 'pass all command line arguments to application' when I built the VI.  What I find strange is that LabVIEW intercepted the argument I was passing and tried to open it using the program registered with windows. I guess there is some reason this is expected behavior.  I have attached the VI which does not work (wrong settings) just for interest. (built with LV2010)
Michael.
(3,158 Views)
