Send a Trigger Signal to a Camera
I am trying to send a trigger signal to the PFI0 channel on my cDAQ-9178 when I press a button. I watched this video that shows how to use "DAQmx Export Signal" to send the trigger signal but it requires a task in/out.
I want to use Boolean button to start the trigger so I was wondering if anyone knows how I can achieve that.
Best
(4,804 Views)
Have you tried to create the Task you need in MAX, or in LabVIEW's Project Explorer?
Bob Schor
(4,789 Views)
This is a small part of a much bigger program that has been written in LabVIEW so I don't know how I can use anything other LabVIEW to create the task that I need
(4,779 Views)
Does anyone know if what I want to do is even possible?
(4,731 Views)
You may find this article on routing signals on your device helpful:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LYVSA2&l=en-US
This should walk you through the process
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHk4CAG&l=en-US
What version of LabVIEW and DAQmx are you using?
Chase
NI Technical Support Engineer
(4,725 Views)
I am working on much the same concept - trying to export a start trigger to a Vicon camera system when I push a 'record' button in LabView.
I'm monitoring analog data coming in from a NI-9205 to set my sample clock and exporting the start trigger to the Vicon via the PFI1 line on a cDAQ-9178 chassis. The Vicon system has a remote start RCA analog input so I'm using a bnc to rca adaptor.
I feel like this should be really straightforward so I'm not sure what I'm doing improperly. Any thoughts?
(4,499 Views)
Search for "Learn 10 Functions in NI-DAQmx ..." and read the article.  It will explain Tasks and how to use the basic DAQmx functions.
Bob Schor
(4,488 Views)
