Send email on labview using the Gmail Server (TLS)
I am trying to using the Google mail server to send email from LabVIEW. I actualy try to use the library of the OpenG OGIC_SMTP. The problem is when talking with the server, I received the message require to do TLS. After sending STARTTLS, I receive this message 220 2.0.0 Ready to start TLS. I don't know what I should do next.
Please tell me what is the next step? I do a lot of googling but only the recommend that after TLS is negotiate with the server. But I don't know how to do that.
I highly appriciate any help.
Best Regards,
Thang Nguyen
Message 1 of 114
(25,351 Views)
Hello Nang,
It would us if you could show which code you used and which protocol you (try to) follow!
Ton
My LabVIEW Ideas
Message 2 of 114
(25,270 Views)
Hi TonP,
Could you please take a look at the VI OGIC_SMTP_Main.vi in the internet toolkit at OpenG? http://openg.org/tiki/tiki-index.php?page=OpenG+Internet+Connectivity+Tools#attachments
You can download at the attachment tab.
Because I still try to modify this function with adding some command, so there is not any vi from myself. That's the reason why I don't have any VI to send you.
Thank you for your patient to answer my question.
Thang Nguyen
Message 3 of 114
(25,248 Views)
I have answered your question, here.
Message 4 of 114
(25,244 Views)
Hi Jim,
I read your answer already. I just want to answer TonP.
Thank you so much for your answer,
Thang Nguyen
Message 5 of 114
(25,240 Views)
I managed to accomplish this fairly easily using the Microsoft .NET Framework.  Of course, that means it will only work in Windows for the time being.  See the attached gmail.vi.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
Message 6 of 114
(24,638 Views)
I have used this gmail VI with decent success.  However, when I attach a file, it seems to leave the file open so that I cannot open it elsewhere in the program.  Is there  a way to fix this?
Andy
Message 7 of 114
(24,402 Views)
I assume that if you close all of the refernces you should have no problem:
Ton
Message Edited by TonP on 10-04-2008 11:12 AM
My LabVIEW Ideas
Message 8 of 114
(24,380 Views)
If possible, could some one please post a version of 'gmail.vi' for LabView 8.2?  Thanks!
Message 9 of 114
(24,226 Views)
Here you go.
Message 10 of 114
(24,190 Views)
