Send python shell commands from LabVIEW
I`m investigating in Labview2018 the possibility to interface to python classes.
What I found out so far is the possibility to call Python functions in Labview2018 , Like;
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3k0CAA&l=en-GB
https://forums.ni.com/t5/LabVIEW/Python-Node-in-LV2018/td-p/3797256
Looking for a way to call python ‘shell commands’ directly form LV.
Example return ‘Python 3.6 version nr’:
   PyVersion.py
         import sys def function():
             return(sys.version)
This works, with normal python function callback.
The coal to directly send the commands from LV:
  import sys
  sys.version
Anyone have some ideas / example code?
Thx
Leon
(4,021 Views)
May be you could use System Exec.vi  and run the py. script which you want directly.
Nghtcwrlr
(4,001 Views)
Hi Nghtcwrlr,
Thx, but I`m looking for an option without creating a ‘.py’ file in this example.
Calling the python ‘shell commands’ directly from LV2018.
Thx
(3,988 Views)
have a look at
https://forums.ni.com/t5/LabVIEW/Streaming-commands-to-a-python-console/m-p/2613903/highlight/true#M...
Nghtcwrlr
(3,979 Views)
