Send / receive negative values over OPC with DSC --> Device failure
I try to send a negtive value (e.g. -1) but the Tag Monitor shows "Device failure". A positve value works fine (Quality: Good)!
When accessed the variable the directly with a DataSocket connection there is no problem with negative values.
Is it possible to declare the datatype of each variable in the Tag Cofiguration Editor? Haven´t found yet ..!
Message 1 of 1
(2,720 Views)
