Send signal from labview to simulink model.
Hello all
I want to send a digital signal which will be high when a start button is pressed and zero when stop button is pressed from labview to simulink model. Is there any simple way to do this other than sending packets through UDP, TCP/IP?
Thank you.
(3,135 Views)
Hi!
Are you running the model using the Simulation Interface Toolkit?
(3,126 Views)
Hi Marco
I don't have simulation interface toolkit. Is it required?
(3,124 Views)
Give a look here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209048
With SIT you can execute your model within Labview and can iteract easily with it, for istance exchanging I/O, setting parameters etc.
Marco
(3,120 Views)
Thank you for the advice. I'll definitely look into it.
(3,117 Views)
