02-12-2010 09:32 AM
Hi all,
I would like to send some of my vi to my co-worker through an email, and I need to find the best way to do it. I have a bunch of vi. They are usually in lvib. Not to mention that many of those vi are interlinked. I would like to select a few of those vi and send them out through email. My question is
How do I send them in such a way that when I prepare the send, I don't have to spend time to make sure I have included every single dependent vi and that when my co-worker open the file there will not be any broken links.
Thanks!
Yik
02-12-2010 09:36 AM
From the project create a Souce Distribution.
Ben
02-12-2010 11:29 AM
Sweet. That's exactly what I am looking for. I never used it, so I didn't know about it. One more question:
Is there a way to make the source distribution for an older version of LV, for example, 8.2?
Yik
02-12-2010 11:36 AM
That has been avaliable in all of the VL version I have used going back to BridgeVIEW 2.1.
In pre-LV8 version is was available under "Save with Options"
Ben
02-16-2010 08:55 AM
Can you give me a few steps? I think I can do the source distribution now, but I can't find the option where you can do source distribution and putting the distribution at a earlier version.
To make a vi into an older version, I know I can do the "save for previous version", but not sure how to do that with source distribution. Thanks!
Yik
02-16-2010 09:07 AM
I think the save for previous will do most of what you get in the Source Distribution. If a simple save for previous gives you too much, do the save in two steps Source Distribution , Save for Previous.
Ben
02-16-2010 09:12 AM
Since LV 8.x, Source Distributions are done using the Application Builder. So if you do not have that tool, you cannot automatically create a Source Distribution.
What you can do in order to create a copy for other PCs without the Application Builder is to select Save As... >> Duplicate Hierarchy to New Location.This is available at least in LV 2009...... (didn't check with 8.x)
hope this helps,
Norbert
02-16-2010 09:16 AM
Norbert B wrote:Since LV 8.x, Source Distributions are done using the Application Builder. So if you do not have that tool, you cannot automatically create a Source Distribution.
hope this helps,
Norbert
Application Builder - Is that is waht I find at the bottom of my project?
For VI's in VI'lib, I think that will get complicated.
Ben
02-16-2010 09:26 AM
Ben wrote:
[...]Application Builder - Is that is waht I find at the bottom of my project?
Ben
Ben,
the Application Builder is as of 8.x accessable from LV projects only and you will need a Build Specification in order to configure it. So you are somehow correct with your q
question 🙂
Well, esp. when distributing VIs from your local vi.lib, you should use the Application Builder since the option i stated for 2009 removes all dependencies into the vi.lib from your "distribution". Nevertheless, the question: how do i distribute vis which are part of the vi.lib should not really occur. The reason: the vi.lib is for components from NI. It is not recommended to include self-written VIs there.
Ok, i am a bit of cheating here (not talking about toolkits), but why must they be part of a Source Distribution?
Norbert
