Sending 1 byte at a time
I have a device that takes byte by byte string command and I'm using the attched file to do this but somehow seems not to work. If I send X66\r, I'm only getting X & 6 back.
Note that sending the same command via hyperterminal works just fine. So what is the best way to do this method using LabVIEW?
Thanks!!!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(3,247 Views)
What do you get if you dont use a for loop?
(3,244 Views)
Do you want to send one byte at a time like your subject says or read one byte at a time like your code shows?
Why are you using the bytes at port and VISA read the way you are?
You might be expecting 3 bytes back, but if there are only two bytes at port at the instant that function is read, then the while loop only runs 2 times, and you only read 2 bytes in total.
(3,225 Views)
Oppps... the attached code was misleading...
Just got an update from our software engineer and what we want is to send the string one at a time.. so how do I set it in that manner.
Thanks!!
______________
KowdTek
LabVIEW 2009
(3,201 Views)
Example in this thread works for me...
Thanks a lot!!!
______________
KowdTek
LabVIEW 2009
(3,176 Views)
