Sending Custom Commands/Queries
I understand what you are saying, I have used that trick for other things in for loops, but I don't see how that is possible if the number I want to change is inside of a string. I would show you what I  am talking about except this is my work computer and it doesn't have labview. I appreciate the help though. I will try a few things to see if they work, but if they don't I will post my problem in a few days with the trial and error vi that I made.
Matt
Message 11 of 15
(934 Views)
And in this case [term] depends on how you set up the instrument.  it has a setting to that you need to use the front panel to set.
Message 12 of 15
(931 Views)
I am not trying to change and output of strings (to form an array), I am trying to increment a number inside of a command string that would would go into a VISA write buffer. That string would be "ZONE? 1,1[term]" and I only want the second 1 to change. I don't think that's what you were thinking of.
Message 13 of 15
(930 Views)
Please read the help for Format Into String. Embedding a numeric conversion with the instrument command is trivial. The format string would be ZONE? % d.
Take the tutorials!
Message 14 of 15
(928 Views)
Or with \code dispaly on "ZONE?\s%d,\s%d\r\n"
Message 15 of 15
(924 Views)
