Sending Hex text files to the Serial Port
Does anyone know or have any experience in how to open a Hex file, read
the data and send it down the serial port.
Martin.
(4,703 Views)
Hi Martin,
There is a function " read spreadsheat file.vi " to load the Hex text file.
Then you use the serial communication.vi to send the string to the serial port.
If your Labviw version dos not contain the serial communication.vi : It is a
simple program which inits the serial port, then writes a string to the port,
and finally reads a string from the port.
Good luck!
Andi Exner
Martin Stanley wrote:
> Hi,
> Regards,
> Martin.
(4,703 Views)
> Hi,
> Regards,
> Martin.
Martin,
I have a vi that reads a hex file then sends the data out the serial port.
It waits for each byte to be echoed back before sending the next one.
As each hex number is read, it's converted to a decimal number. The number
is used as a decimal ascii code, the ascii character is then sent to the
serial port.
I'm not sure if this is the most efficient way to do it, but it works.
Walter
(4,703 Views)
Dear Martin,
 Now i'm looking for sending the data from hex file through serial port. I think your program is very useful to me. Can you share the program?
(3,226 Views)
You do realize this thread is over 19 years old and Martin has not visited the forums for nearly 18 years, right?  I highly recommend you start a new thread with a lot more details on your problem, including what you have tried so far.  An example file would also help clear a lot of confusion.
GCentral
(3,220 Views)
Also try searching the forums.  This question comes up periodically, and I think at least twice in the last few months alone.
(3,214 Views)
