Sending IR (HEX) using myRIO
Hey guys,
I'm planning to control the Temperature of the AC in my room using the myRIO. I used an arduino and a TSOP and got the various HEX codes. It Looks like this
Raw: (139) 9076, -4484, 668, -1628, 676, -1628, 676, -528, 672, -536, 672, -532, 672, -528, 676, -532, 672, -528, 676, -528, 676, -532, 672, -528, 676, -1628, 672, -536, 672, -532, 672, -528, 676, -528, 676, -528, 676, -528, 676, -532, 672, -532, 672, -528, 676, -528, 672, -532, 672, -532, 672, -532, 676, -528, 676, -528, 672, -532, 676, -1628, 672, -532, 672, -1632, 672, -532, 672, -528, 676, -1628, 672, -532, 672, -19976, 668, -560, 648, -556, 648, -556, 672, -532, 648, -556, 648, -556, 648, -556, 672, -532, 672, -1628, 652, -552, 648, -556, 648, -560, 644, -556, 648, -1656, 648, -556, 648, -556, 652, -552, 644, -556, 648, -556, 648, -556, 648, -556, 648, -556, 648, -556, 648, -552, 648, -556, 648, -556, 648, -556, 648, -556, 644, -1656, 648, -1656, 644, -1656, 648, -556, 648,
I need to transmit this to a IR Tranmitter Diode using the myRio. The labview program will consist of a case structure where "increase temperature" will transmit the above IR hex to the transmitter. What is the best way to do this?
Message 1 of 1
(2,443 Views)
