Sending Raw Data via USB
I have custom software I use to send commands to my custom USB device.
Ex.
byte{} Send_packet = { 0x83, 0x0D, 0x80, 0x0B, 0x01, 0x00, 0x06, 0x00, 0x00, 0x21, 0x01, 0xFF, 0x43 };
I want to use LabView to integrate it with the rest of my testing.  I started off using the USBRawBulkMain.vi Front Panel to get started.  I crated the VISA driver to communicate with the device and used NI I/O Trace to verify the output to the USB.  I want to send the raw data as in the example above but it doesn't like that.  Can anyone give me some tips on how to output such a command?
(4,180 Views)
Hi lightstring,
We have some documentation on using USB RAW. Have you looked through these documents on how to get started?
USB Instrument Control Tutorial
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US
How Can I Communicate With a Device Using NI-VISA USB RAW Mode?
http://digital.ni.com/public.nsf/allkb/E3A2C4FE42D7ED0D86256DB7005C65C9
Jared T.
(4,141 Views)
