Sending SMTP email with server that requires authentication
I've attached an example of smtp with authentication and attachments.
HTH
Best Regards,
Joachim
Message 11 of 18
(4,258 Views)
Hi Joachim,
I haven't LV2011. I have 2010. Can you convert the vi? Thanks
Message 12 of 18
(4,255 Views)
HTH
Best Regards,
Joachim
How is this example different than the one posted at the link provided? Other than the fact you put in a case structure around it and straightened up some wires.
Message 13 of 18
(4,246 Views)
@GT123 wrote:
Hi Joachim,
Don't bother, it's the same as the previous example.
As for your 1172 issue: you need to check to see if your emails are being blocked by your firewall. This is a common problem. If you are doing this in a corporate network, check with your IT department.
Message 14 of 18
(4,245 Views)
I`m still have the error 1172 with this email vi "gmailLV86.vi", but I can say
- i have the correct mailserver address and port and account with password, and no ssl
- we have an backupserver who send emails at this exchange server with the tested values(adress...)
- the email account works, because: i can send an email with a LV and activeX (Outlook), but then I have to click yes because of a outlook
   warning (in enlgish like this):  "An application wants to send an autommated emails in behave of..."
- if I send an email with the smtp email send message.vi -> error:
TCP Open Connection in NI_SMTPEmail.lvlib:SMTP Email Open Session.vi:3->NI_SMTPEmail.lvlib:SMTP Email Send Message Charset.vi:2->NI_SMTPEmail.lvlib:SMTP Email Send Message.vi:1->email_smtp.vi
What is the reason? I think it has to be possible to do this with labview. Thanks.
Message 15 of 18
(4,227 Views)
try this : http://forums.ni.com/t5/LabVIEW/ogic-smtp-library-example/td-p/454028/highlight/true
use the OGIC_SMTP_LIB  to send mail.
regards,
eyal.
Message 16 of 18
(4,222 Views)
Just to add to this thread, I have also made a modified version of the original SMTP VIs that has simple authenticatation (No TLS/SSL though). However, it does have the advantage that it works without .NET (on any OS or on LabVIEW RT).
Eric
Message 17 of 18
(4,121 Views)
Hello BlueCheese, can I have this in LV2010. Thank you very much
Message 18 of 18
(4,112 Views)
