Sending Values to a front panel cluster
Hello
I am fairly new to LabVIEW and struggling to understand how I send a numeric value from one of my sub vi’s to a numeric indicator in a cluster on the main vi’s front panel? I have been able to send control values to the vi using the method in the snippet.
Unfortunately I cannot share my vi so have simulated the layout.
 Thank-you in advance.
Mick
(2,669 Views)
In general you shouldn't use the control refs to send data like that, but connect the control/indicators to the VI's connector pane and send the data.
That being said, you need to read the cluster first so you can use a Bundle with name to change a specific part and write it back.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,661 Views)
Hi Yamaeda
Thank for your reply, my original vi did use the connector pane as you described but the vi was becoming cluttered so i ended up changing it for the present, I apologize for my lack of understanding put could you show me an example of your second suggestion.
Mick
(2,643 Views)
Accepted by topic author Iberian2000
Bundle by name.
Qestit Systems
(2,639 Views)
Brilliant !
that worked a treat thank-you.
Cheers
Mick
(2,632 Views)
