Sending Voltage Signal from FPGA
I want to send a TTL voltage signal from LabVIEW FPGA (NI 7856R Series) to a laser shutter and flipper to control them. How can I do that with this NI FPGA Module? I was reading some articles and comments, and some were saying about setting up a digital signal that will transfer to an output signal, but wasn't very clear.
Message 1 of 12
(8,016 Views)
How to you communicate to the shutter and flipper? Are the also TTL? Or serial? Or GPIB?, USB, TCP\IP? That is kind of critical...
Message 2 of 12
(7,965 Views)
They are TTL Pulses.
Message 3 of 12
(7,954 Views)
So make a loop that gets the input, do some logic and sets he outputs.
Message 4 of 12
(7,946 Views)
BTW, the DIO-lines of a 7856R-card use LVTTL levels, i.e. high is 3.3 V, not 5 V as in TTL. So you either have to use an analog-out for a 5V signal or you have to look for some additional hardware that can convert the LVTTL to a TTL level.
Regards, Jens
Kudos are welcome...
Message 5 of 12
(7,935 Views)
Regards, Jens
TTL levels require an input above 2V for a logic high or an input below 0.8V for a logic low. Seeing that the 3.3V output of your FPGA is above the 2.0V level, a level shifter should not be required.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 6 of 12
(7,925 Views)
@Minions wrote:
Regards, Jens
As I see it, 5V TTL might blow the input. 3.6 is max:
https://forum.allaboutcircuits.com/threads/cmos-and-lvttl-voltage-levels.62014/
Not sure if the 7856R can take more, but if it's spec'd at LVTTL, it's not required to.
Two resistors will fix that. Still inconvenient, depending on the situation...
Message 7 of 12
(7,920 Views)
wiebe@CARYA wrote:
@Minions wrote:
Regards, Jens
This is all a non-issue as long as the FPGA is being used as an output to control the external equipment as stated in the original entry.  Smiley Tongue  If the FPGA is used for monitoring any responses or inputs, then this may change.
Message 8 of 12
(7,913 Views)
@Minions wrote:
wiebe@CARYA wrote:
@Minions wrote:
Regards, Jens
In the OP In my head there is was an input.
Message 9 of 12
(7,908 Views)
Thank you all for the comments. I am using the FPGA DIO line to send a signal to a shutter to open/close. I shouldn't be needing a level shifter for that one? I connected a DIO (Output) to a switch that turns on/off, but my shutter doesn't move.
Message 10 of 12
(7,895 Views)
