Sending a cluster to a graph.
Dear All,
I want to display a 2D-array in a graph. But the "Y" port of the build waveform.vi can't receive 2D-array. So I want to make a cluster instead of the waveform.
But I can't understand the meaning of the second port.
Is it like the "delta t" in the build waveform.vi? Maybe not. I have tried, but can't work properly.
Please help me to explain its meaning.
Thank you.
(2,555 Views)
Please attach your image directly (we would need a password to see your image at storage.msn.com.)
Why don't you just wire the 2D array to the graph terminal directly? You can always set the deltaT manually via the graph properties or programmatically via a property node (Xscale:Multiplier).
(2,545 Views)
Dear Altenbach,
Oh, I am sorry to here that you can't see the picture. I rarely paste pictures in the forums. I tried to find a good way to do it next time.
I have just tried to use graph's property. That works properly.
Thank you!
(2,538 Views)
