Sending a packet structure
@billko wrote:
@BertMcMahan wrote:
@billko wrote:
Doesn't "Flatten to String" have the option not to include the size when flattening?  Anyway, a cluster is better also because it strictly defines how big the message is.  There's no way to send the wrong amount of bytes.
Edit: Oh, I was assuming that you were using the "Flatten to String" to send it as a message over a network or something.
Yes, FtS has an option to include the size of a string or array when flattening, BUT if the string or array is inside of a cluster, it will ignore this and will always include the size.
This is a packet is being sent somewhere.  The cluster shouldn't be flattened; right before it is to be sent, it should be unbundled, and all values converted into an array of U8 and be sent in order.  (It's highly unlikely that the recipient of the message will be expecting a LabVIEW datatype.)  That's why it never occurred to me that the option would be ignored.
No, there is no need to go through the extra work of unbundling the cluster and building the array. Given the packet definition above, if you use Flatten to String on the cluster you will get the serialized data which perfectly matches the packet definition. I have used this approach extensively and have not had any problems. Using this method I have sent complex structures not only to other LabVIEW applications but to applications developed in other languages.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 16
(887 Views)
I am fairly new to programming nor the LabVIEW world. Most of the things which you have put are hard to comprehend. Could anyone would be kind enough to share a snapshot of how the wiring of the packet structure could be done so that I will learn and seek an opportunity to grow. Thank you in advance.
Message 12 of 16
(876 Views)
This is essentially what everyone has been talking about.
Mark Yedinak
LabVIEW Champion
Message 13 of 16
(856 Views)
THAT is something I will add to my notebook!  It doesn't prepend size info?
Bill
CLD
(Mid-Level minion.)
Message 14 of 16
(839 Views)
No, the size will not be prepended to the data. The input on FtS to prepend the size ONLY applies if the input is a string or an array. If the input is a cluster, it simply serializing the data. It will honor the "endianess" input for numbers and it WILL prepend the size of any array or string inside the cluster.
Mark Yedinak
LabVIEW Champion
Message 15 of 16
(837 Views)
Excellent stuff.  I appreciate your patience.  🙂
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(828 Views)
