Sending an Labview Image to a .Net program
I have a labview vi that grabs a color image from a camera and displays it. I would also like to send this image to a different machine over TCP or Datasocket to a .Net program (the language is not important to me) that would display it. I am not sure of what is the most efficient method/respesentation for the Labview image that would make it easy to restore this image into a .Net Bitmap.
Thanks in advance,
Michael Terk
(2,955 Views)
Hello M.T.,
I would suggest using the IMAQ Image to Array VI to get an array representation of the image. Then you can convert the 2D array into a string by using the Flatten To String VI to send the information over DataSocket or TCP/IP.
The following document shows some pros and cons of streaming images over TCP/IP and DataSocket.
The following document shows an example of how to stream images over DataSocket [broken link removed]. This document also includes a link to an example program demonstrating how to do this.
Wendy L
LabWindows/CVI Developer Newsletter
(2,934 Views)
