Sending an array of different data types over a serial connection
I am interested in sending an array of various data types over a serial connection. I currently have what the bit structure of the data message is supposed to look like and now need to implement it in Labview. Any help would be greatly appreciated.
Message 1 of 13
(4,645 Views)
You want to use NI-VISA to do the serial communication. VISA communication is via strings, so you need to convert to/from strings in order to transfer data.
Cheers
Message 2 of 13
(4,642 Views)
An array can only contain a single data type so your question does not make much sense. Do you actually have a byte structure? Why don't you share it?
Message 3 of 13
(4,598 Views)
Thank you for your reply. Here is an example of what my byte structure looks like:
Data Type                     Byte Number
Numeric                       0
Numeric                       1 - 4
Numeric                       5- 8
Boolean                       9 - 12
Enum                          13 - 16
This goes on for approximately 256 bytes. I need to send them in the order they are listed over a Serial connection. I will also need to read from an external non-National Instruments device through serial, which will have a different byte structure with the same Data Types.
Each variable is 4 bytes long, with there being a few status bytes at the very beginning being 1 byte.
Any help is appreciated.
Thank you.
Message 4 of 13
(4,503 Views)
If the byte order is always the same, I would just make a cluster with all of the data and then use Flatten To String.  You can then send that string using the VISA Write.
For the read, I would do the same thing except read with the VISA Read and then Unflatten From String.
Message 5 of 13
(4,490 Views)
Ok thank you. I am going to go with the flatten to String method. I have another question. I need to run a for loop that performs certain operations depending on the value of N, but after it runs an N number of times, I need it to reset the N to 0 and repeat this process. I think shift registers are the method I should use but I am not entirely sure of the syntax.
Message 6 of 13
(4,457 Views)
A For loop inside of a While loop? Specific operations based on the value of N would be a Case Structure with N wired to the selector. I think that's what you're getting at, but I can't be sure because your sentence structure could mean N different operations, or a single operation based on the value of N.
Cheers
Message 7 of 13
(4,453 Views)
It would be a single operation based on the value of N.
Message 8 of 13
(4,444 Views)
Specific operations based on the value of N would be a Case Structure with N wired to the selector, all inside of a While loop. Use a shift register if you need the previous loop's values.
Cheers
Message 9 of 13
(4,438 Views)
Ok, thank you. I understand that part. My question is, how do I continuously run this loop N number of times, resetting it back to 0 after each N times. I need to repeatly send data over a serial connection that sets certain fields to certain values depending on this N value. Each iteration is one message and after N number of times, it resets and repeats the process. Hopefully this clarifies.
Message 10 of 13
(4,423 Views)
