Sending array over TCP receiving array and creating image
@billko wrote:
Just be aware that every time you convert a floating point number to a string, you lose the actual floating point value.  You get an approximation of an approximation.
Not if you use the Flatten To String and then Unfaltten From String.  Those mostly just cast the raw data to a string, with options for how the data should be cast (Endianness, include string/array sizes).
Message 11 of 11
(617 Views)
