Sending commands to web page
I may be faced with the task of controlling a device which only serves up
web pages as a user interface. Does anyone know how I'll need to format commands
for button clicks, text boxes, pull down menues, etc. I've done a few experiments
with TCP Write but haven't had much luck yet. In case it matters, I'm using
LabVIEW 6i on Windows NT and I also have the Internet Toolkit.
(2,694 Views)
Basic guideline looks like follows:
1.Use TCP connection to port 80 (most likely client is using this port
if not search exact port number in documentation)
2.Get client's web page with buttons and controls. Parse HTML code for
the following:
These will form prototypes for you
r commands to client.
3. prepare your data and put it into found controls on appropriate position.
4.send prepared commands back to device
5. get the reply from device.
The all communication going through strings.
There are some details,so you should be familiar with an HTTP format and
forms. It depends on your client's web server protocol and specific.
Hope this helps a little.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(2,694 Views)
