Sending data via TCP
I'm using Labview 2018 and I been trying to test the TCP read/write function and having some issue and getting a few errors. I'm mainly wondering if there is a way I can just send data (A 1-D array to be specific) via the TCP function and then receive it back at the same computer, so basically sending it in a loop.
(2,462 Views)
What issues and errors did you get?
(2,429 Views)
Attach the code you are using that doesn't work.  Did you look at the examples that ship with LabVIEW?
Bob Schor
(2,426 Views)
