Sending graph image to printer?
I'm using Measurement Studio in VB6 and I'm needing to send the graph
image from a CWGraph to the printer object. Does anyone know how to
do this? I can print the graph if I use the printform method, but I'm
needing to send everything directly to the printer. Any ideas?
Dave
(3,361 Views)
You've posted your question to the wrong forum, this is for LabVIEW questions. For Measurement Studio/Visual Basic, go to here.
(3,361 Views)
You can do:
Printer.PaintPicture CWGraph1.ControlImage, Width, Height
Where Width and Height are single-precision values indicating the destination width and height of the image. You can also specify other parameters of PaintPicture to change the size of the image and so on.
Mika Fukuchi
Application Engineer
(3,361 Views)
