Sending unsigned byte array to serial port
I would like to send a string of hexadecimal values to the serial port (using the "VISA write" block).
At the moment, I have a working design that will take a string of hex values, and convert them into an unsigned byte array.
However, it would seem that the "VISA write" block only accepts a string as its input.
If I use the "Byte array to string" block, then I can only convert the hex values that correspond directly to ascii characters.  I.e. it will only convert hex values that lie between 0x20 and 0x7E.  However, I need to be able to send values in the range 0x01 to 0xF8.
Any suggestions welcome.
Dan
Dan
CLD
(9,347 Views)
Have you tried using escape sequence? For example \20 is a space, \30 is 0.
(9,336 Views)
No it doesn't. Why would you think that?
Message Edited by smercurio_fc on 07-22-2009 08:49 AM
(9,332 Views)
I have also used typecast:
It really depends on how explicit you want the code to be, using Byte array to string is more obvious. Both execute in less than a millisecond on my machine.
(9,292 Views)
Never mind. I didn't see all the other replies before I started typing mine.
Message Edited by Ravens Fan on 07-30-2009 12:30 AM
(9,265 Views)
please if you have found the solution told me I have the same problem
(5,835 Views)
What specifically is your problem? As explained above, there is no problem with converting between byte arrays and strings.
(5,826 Views)
