Sensirion ek-h4 / Humidity Sensor SHT21 - Error 1386
I was using the Sensirion ek-h5 before and because of your help (Link) I could make it work with my LabVIEW program.
Now I switched to the ek-h4 and I was happy to see a LabVIEW GUI (Link) from Sensirion. However, the program does not work at all, I always get the error 1386 (see attachment).
The constructor node in the SubVI "CreateReferences_EKH4.vi" causes the problem and I found this similar thread: Link
However, I could not make it work after several hours of trying (I'm kind of beginner in LabVIEW).
Also the Sensirion does not seem to start (black display) as I start the LabVIEW program.
With the viewer software from Sensirion (V2) it worked for me.
I am using Windows 7 and LabVIEW 2015.
If you need any additional information please let me know.
I welcome your help a lot.
Tobias
(3,877 Views)
Accepted by topic author PTobias
Hi Tobias,
Great early troubleshooting attempts. It looks like the error is happening in your subVI "Create References_EK-H4". Can you post a screenshot of, or even the actual subVI?
Your error message indicates this is happening when you attempt to use a constructor node to create a .NET object, which means there is an issue with the .NET assembly you are trying to access.
You may find this KnowledgeBase article relevant: http://digital.ni.com/public.nsf/allkb/4742EB60B64BE22186257BCE0053B8FD?OpenDocument
(3,822 Views)
Hi Kodester,
Thank you so much!
The solution was in the provided link.
It was so easy. I just had to do this with the *.dll files:
"Tip: In Windows 7 or later, you also can right-click the assembly and click Unblock on the General tab to grant an assembly full trust."
Thanks again.
(3,809 Views)
